During bias voltage measurements on SWR SM900's (early versions) and 750x amps during routine preventative maintenance, I made the fatal mistake of connecting my long EZ-Hook DMM probes onto the emitter terminals of the two driver xstrs. The connection to the lower half driver xstr's emitter terminal (Q8 on 750x) is easy enough to get at. The same on the upper half driver xstr's emitter terminal (Q7 on 750x) is not so easily accessed, though I did finally get my probe onto it, with the power off. Powered up, monitored the output DC level of the amp and the DC voltage of the bases of both drivers, typically 1.0V between them, enough to get the outputs close to turning on, but not. If you tweak the bias pot lower than 950mV, it will often drop off quickly, and you'll see a change in the AC mains current. I know....measuring the voltage across the output xstrs' emitter resistors shows the current is starting to flow, and usually set for around 10mV across them. I check that too, but have gotten in the habit of looking at the emitter's of the two drivers (tends to be more accurate in fully complimentary output stages than these quasi-comp stages).
All was fine until I went to disconnect the probe on the upper driver Q7, and while I've done this so many times in the past carefully, making the connections to the device terminals while power is on can be hazardous if your hand/probe slips. My probe must have slipped while disconnecting and removing it from the terminal, contacted both the emitter & collector, saw an arc and flash of light from the insides of the fuse holder, then all was quiet. Fan coasted to a stop. I bought the farm. RATS! What was worse, was a far easier connection for Q7's emitter was right there to the right, the base terminal of the top output xstr....easily accessible, without a nearby hazard begging for trouble. The damage was all six output xstrs failed (Sanken 2SC3264's) & the driver 2SC4382.
Same condition holds true on the early versions of the SWR SM900, as shown in the last photos.
750x Power Amp Rev E Sch.pdf
