Just finished a second supro 1624t kit, having some issues. Using this basic layout http://www.sluckeyamps.com/supro/supro.pdf but made a couple changes. kept the 7w 250ohm 25uf 25v arrangement like the original and left off the tremolo section entirely.
I raised the stock 1.5k on v1 35uf cap to 8.2k to make v1 pin 1 come up around 200v v1 like the schematic. v1 Pin 6 is about 110v.
I used a 10w Valco clone power Classic tone 40-18062 and matching classic tone 40-18063 10 watt output. JJ 5y3- EH6973 power tubes.
Right now the voltages all look really spot on to the original but when the vol 2 pot or tone control is turned on a bad distortion buzzing shrill honking sounds takes place. Squawking sound when you hit the standby switch to cut power. When Volume 2 is Left off the sound is fine and controls work on Vol 1 pot and tone pot.
But separate issue for some reason the amp seems not near as loud as I would expect with a single C12r 25w 8ohm Jenson 12".
Any ideas on the noise possibility and how to beef or mod this thing up for a little more output?
