Hey y’all, I have a 1975 fender twin on the bench. The vibrato channel has low output, and I’m losing signal before the 12at7 phase inverter. Clean channel is coming through crystal clear, so it’s somewhere before the channels merge. It sounds easy but it’s really taking a long time for me! Can someone help me out with where I should be probing? I have a feeling it’s probably a bad connection. It was working on the bench all of yesterday and this came up right before I left. Thanks!
1975 twin reverb vibrato channel issue
Actually, after I put it in the cabinet for the final check, it started smoking and the fuse blew. So, there are obvious power supply issues with this amp. Output tubes were holding a bias, everything looked good. I see now that there is a crack in one of the resistors between the grids of the output tubes, but I'm not sure if that is a result of overheating just now. Just blew my variac too...
Do you mean the 470ohm screen resistors? If so, they generally burn due to a defective power tube.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Steelwitch View PostJust blew my variac too...Logic is an organized way of going wrong with confidence
Originally posted by nevetslab View Post.....blew my variac too....? Hopefully it was a fuse for the variac, and not the coil or wiper assembly of the variac. I have both General Radio and Superior Electric variac's (Variac is a trade name for General Radio, not that it matters), and have over the years pulled them apart to service the wiper assembly, replace the wiper brush, spring in that assembly, etc. I've never had a coil fail.
While I have this thread open: there is a fair amount of noise when the MV is all the way up— basically from what it looks like, someone did a terrible job dressing the heaters, so I’m gonna go ahead and redo that. Do y’all have more success with lead dressing against the chassis, out of the way from crossing over other potential sources of noise, or elevated, but neat and tidy! Also wondering if any oscilloscope wizards have tips for identifying noise coming from old caps either with ac or dc coupling. What’s easiest? Do these white mallory’s always come out? Lol they don’t seem to age well
