Recently fixed up an old VC50. Cleaned the pots, jacks and fixed it with a set of tubes that ran in good range. Cleaned it up, replaced the grill etc. Sitting pretty ,looking good, sounding good...until I tried the FX loop. Plug into it and the sound dies. Checked the cable Im using in my other VC50 and its fine. Its a TRS single jack loop.
Looked over the solder joints -nothing. Contacts look ok -wiggling does nothing. Power is coming from the power amp section cause I get loud hum if I touch the return end of the insert cable. Hopefully someone can give me a heads up on where to look. Thanks Bob
http://www.chasingtone.com/schematic...ge_club_50.pdf
