Was asked to look at a Kendrick bass amp with tube rectifier that has a low hum not scoped yet could be 60 or 120 hz. Amp sounds fine except very low hum. Hum very low but steady no preamp volume or tone control effect. No effect with ground reverse switch. Same hum with both power tubes removed...could it be something with the output transformer..?
I cant locate a schematic.
Should I go right to the electrolytics?
I would appreciate any suggestions. thanks.
