So I am ready to fire this bad boy up and finish it off but everything is telling me to beware of these output tubes. My other thread involved reattaching the plate caps so they must have been cooked pretty good. Unfortunately these tubes are not that easy to test on my Hickock tube tester since the plug on the tester for the plate cap will not fit. My worry is that I just discovered that one of the 6146 plate resistors is open and two of the screen resistors are open. This does not make me feel very confident in the current set of output tubes at all. I have an order in for the screen resistors and I am going to replace any bias related resistors, including the 1 ohm cathode resistors too. Is it possible for a plate resistor to be open and the related tube to still be good?
I see a sextet of Chinese 6146b tubes on tubes and more. Are these things reliable? Probably the only way that I will be able to get a matching sextet is by ordering them new.
https://www.tubesandmore.com/products/6146b-chinese
