Hey everyone. There was a Fishman Performer that someone brought in and asked me to repair last week. It was a US model and he had plugged it right into a UK power outlet, blowing it. I took it apart, replaced the fuse, but I also noticed that you could solder a jumper on the power suppler board to convert it from 110V to UK 240V, so I jumper that wire aswell. I turned on the amp, it worked fine and gave it back to the guy.
He brought the amp back in the next day, saying that when he made to turn it on the power light flashed on for a second then almost immediately turned off and the amp hasnt worked since. I took it apart again, double checked everything I've done, tried a different power cable and replaced the fuse again (Wasn't blown). I drew out the power input schematic and it seemed to all be working correctly, which leads me to beleive theres something wrong with the power amp board. Theres still voltage on the transformers output, so apparently that hasnt been blown.
Im at my wits end, a visual inspection shows that nothing seems to be out of place and the components look alright. Is there any recommended troubleshooting steps that you guys can reccommend?
Thanks alot
Thanks alot
