Speaker out distorts at a very low level.
Preamp out is also distorted. This would seem to show where the trouble is - but does it?
Inserting an open plug into the Poweramp In jack - to separate the Pre Out and Power In - cleans up the preamp!
Or:
Removing the 12AX7 from the power amp also cleans up the preamp! Tried two other 12AX7 with the same result.
What would:
Cause the 12AX7 to have such a low Z-in that it loads down the preamp?
Or:
Cause the 12AX7's grid to have enough voltage on it to turn on one of the clipping diodes that are in parallel with the input?
Before you ask, no, we have not yet tried another tube in the preamp, measured the voltages on the amp 12AX7's socket, nor removed the clipping diodes to see if one is faulty - that's for Monday.
Or:
What would:
Or:
