After getting my YGM-3 running again, the reverb is not working. I pulled the tank out and had to fix two bad connections on those very thin wires connecting the RCA jacks.
Still no reverb. I measure and noticed the following.
Gibbs tank probably original. I cannot find any specs on the tank, the pan is very rusty. I am reading 1.2 ohms input impedance, and 170 ohms output impedance.
Original tank input cable reads good continuity tip to tip and ground to ground.
Original tank output cable reads good continuity tip to tip, but there is no ground to ground continuity. The ground is connected at the pan side RCA plug, but there is no ground connection at the amp side RCA plug. I think this may be intentional to prevent ground loops?
I tried a different set of cables, still no reverb. At this point I think the tank and original cables are good. Although the impedance readings seem low especially on the input.
I also sometimes notice a tick sound when I dial up the reverb knob. I think this is the tremolo pulse.
I still have more research to do on these problems. Any help and advice greatly appreciated.
Thank you. MarkO
Thank you. MarkO
