Ampeg V2 finished up, but when I touch the input reverb cable I get a shock. Then when I put my meter on it, there is no voltage. I figure that C209 is bad, so I replace it. I test the amp, everything looks great, so I power down by pulling the AC plug to drain the filter caps, and as I go to put the reverb cable on the tank, Snap!
Is that .47 cap charging up and biting me? Is this normal?
https://ampeg.com/support/files/Sche...20Version).pdf
