I have no heater VAC on v1 and v2 but have it on v3 and v4............
mesa rocket 44 help
Originally posted by etneccas View PostI see it now I downloaded a schematic......The amp's power tubes are redplating though I have the followimng voltages and could use some guidance troubleshooting pin 2 -11vdc pin 7 483vdc and pin 9 452 vdcIf you don't know where your going any road'll take you there : George Harrison
Bias sounds ok, but plate voltage is crazy high.
https://music-electronics-forum.com/...0&d=1258342282Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by drewl View PostMesa runs their old EL84 amps insanely hot and they eat output tubes.
Not saying adjustable bias is not a good idea, just don't think the 480V at the plates is right. Maybe oscillation.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Yeah as drewl mentioned they run them insanely hot. My DC-3 was 420VDC on the plates and only -11 as designed. No tubes would run less than 110%. The neg grid voltage needs to be at least -14 not -11 vdc thats not enough. That said 483vdc is WAY above design- unless the OP measured without the tubes in place? Bob"Reality is an illusion albeit a very persistant one " Albert Einstein
My Bad the volt measurements were without the power tubes in....Pin9 is 320vdc and pin 7 is 400vdc the functioning but is very crackily and distorted on the contour channelive swapped the preamp tubes around and still have the problem There is a copper foil shield on V2 that tube base makes a similiar sound of cracking when I chopstick it I'll try to retension the socket
Originally posted by etneccas View PostMy Bad the volt measurements were without the power tubes in....Pin9 is 320vdc and pin 7 is 400vdc the functioning but is very crackily and distorted on the contour channelive swapped the preamp tubes around and still have the problem There is a copper foil shield on V2 that tube base makes a similiar sound of cracking when I chopstick it I'll try to retension the socket
Take a good look around. The amp gets really hot which translates into some decent temp swings on the board. I use really good light and two pairs of readers (yep, probably looks ridiculous) when hunting for cracked solder joints."Reality is an illusion albeit a very persistant one " Albert Einstein
One thing I will mention about these is that the PI tube current affects the bias. So if you have a change in the bias condition out of the blue, it could be PI tube related.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
