Repairing a 1975 Fender SF Master Volume Pro Reverb that has been sitting, unused for probably 30 years. My brother, the original owner, asked me to clean it up and refresh the capacitors, etc. When I removed the amp, I noted the chassis had been bent near the Master Volume control.
I straightened this as best I could, reference my posting here:
https://music-electronics-forum.com/...ighlight=sleet
I finished my initial repairs and decided to test the amp and ran into some issues:
The amp is quite save for some crackling noise when I exercise the MV control. When I plug in with a guitar on the normal channel, initially it was loud and sounded pretty good. Moving over the the vibrato channel was not as good. I found that the volume level was much lower and the tremelo did not seem to be working. Working the volume, treble, bass and MV had little to no affect. The volume could be quiet at "1" but would only increase a small amount while at "10". I noted that the MV with it's push-pull switch position (in or out) made no difference to the sound on the normal channel, not distortion was introduced. The MV was apparently damaged as part of the chassis trauma. I noticed this and attempted to source a replacement, but found that the part received would not fit due to the slant of the front of the chassis. I had hoped to keep the amp original and just replace the MV. The other issue now is that both channels suffer from crackling when I aggressively attack the strings on the guitar, less so with gentle strumming. The foot switch seemed to make little difference on the sound on the vibrato channel.
For diagnostic purposes, I know I need to bypass the MV and see if the crackling and low output problems are solved. There are probably other issues as well. I think my brother would be okay with bypassing the MV, and leaving the control in place for cosmetic reasons. I've also considered repurposing the MV control for other things like a reverb dwell control or the like.
Summary of work performed:
Replaced other electrolytics (coupling caps, bias supply, etc)
Cleaned the pots.
Other information:
Original tube complement which I was unable to test, I'm going to check the bias on the 6L6's and have some NOS tubes ready to go if need be.
Thanks.
fender_cbs_45w_mstrvol_pullsw_super-pro-bmstr_rev_sch.pdf_1.pdf
Cleaned the pots.
Other information:
Thanks.
