Originally posted by Randall
View Post
Either the hum is after the Vol2 pot or not. Set the control about 1/4 way up and try shorting between the ACW and CCW pins of the vol2 pot. If it goes away the problem is before.
If before, first try putting a cap say 0.1uF in parallel with the 0.05uf ( I would have used a much bigger value but I guess this was a cost constraint as the time) on the supply to V2. Failing that work your way through the bass circuit first, grounding one point at a time to see what makes it go away. Same with treble. You can even ground the plates of V2 as the series resistance from the supply is high.
