I´ve built a Princeton Reverb clone, but I can´t get the reverb working properly. Otherwise the amp works fine.
What I´ve done so far is to check that it´s wired correctly, and tried different tubes in V2 and V3. I´ve gone over all the solder joints. I´ve checked the voltages, and they´re spot on. I´ve tried a different set of rca cables and a different reverb pan. With the reverb pot turned clockwise all the way, the dry signal becomes is inaudible and there is a very faint reverb sound which decays very quickly. If I tap the pan there is a faint sound of thunder, so it´s not completely dead.
As I turn the reverb pot clockwise, the dry signal becomes lower and disappears when the pot is turned all the way. Is that normal? This happens both when the reverb is turned on and off on the footswitch.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
