I’ve got a Blackface Vibro-Champ which had a massive hum- it had a bad filter cap (CE Dist can) that I replaced, but although the hum is now gone, there’s a static that I can’t quite get rid of.
It goes away when I turn the volume down, or ground the grid on the first stage, or lower the wall voltage with a variac below 100 volts- the amp has a replaced power transformer and the voltages are a little high.
I’ve been able to quiet it somewhat by soldering the ground bus to the chassis.
I’ve thoroughly cleaned the ground bus, replaced the grounding washers to jacks and pots. I’ve replaced the plate-load resistors and the filter caps, installed a NOS RCA 5Y3GT to get the voltages a bit lower, tried a shielded cable from the input and tried replacing everything in the circuit around V1 (including the input jacks,resistors and the tube socket,tube).
Haven’t tried moving the mix resistors from the inputs to the grid on the tube socket. And the heaters have not been modified, their still grounded at the sockets (there’s an open center-tap on the power tranny).
Anyone know where this noise is coming from and how to get rid of it?
