If I remove the high voltage to the power amp the -/+25v and the respective -/+15v rails are present. With the HV connected it drags down my low voltage supplies. I rechecked every single diode and pretty much every component on the board but can't find anything suspicious.
I am wondering if it's possible if the secondary HV & LV windings on the transformer have shorted together somehow. I know jumping to the transformer as the possible fault is unlikely but how would I test for this? Obviously I ohm out the meter between HV & LV connections on the transformer. Is it correct in my thinking that I should not see resistance between these separate windings?
Edit: there is no short between HV and LV on the transformer windings.
