Hi To All,
I recently picked up a non-working, well road worn Peavey XR-600C for us to use for our band rehearsals. The problem was no sound output. The person I bought it from said it would not pass a signal but sometimes it would come on if you talked very loudly into the microphone. The power never went off or blew a fuse.
When I got it home I did the input-output jack troubleshooting and found the following.
From main out to main in (everything worked but the graphic EQ section)
From Graphic Out to Power Amp In (everything works including the Graphic EQ section)
Since I can get everything to work when going between the Graphic Out and Power Amp In jacks and reviewing the schematic (attached) I’m thinking that the power supplies are working correctly and there is a good chance that the Power Amp In jack is bad or needs to be resoldered. (Cleaning it with CAIG did not help). There are a couple of input jacks that I think need to be repaired in this matter. Before I open it up is there is anything that I’m missing with this conclusion and should look for? XR600C- XR680C.pdf
Thanks in advance for any suggestions
dadroadieXR600C- XR680C.pdf
