Marshall Artist, extremely low volume output.
  • Marshall Artist, extremely low volume output.
    Hi, I have an old 80s Marshall Artist, 30 watts, 2 EL34s. The amp had worked fine for a number of months but now it has a super low output. I have determined the preamp section works fine because I ran the effects send to another amp. Both channels operated as they should. I substituted the phase inverter and the power tubes from another working amp and the problem persists. Here are the voltages from the power tubes:
    V2 V3
    P3 488V 489V
    P4 486V 487V
    P5 -49V -49V
    P6 488V 488V
    Any assistance would be appreciated.
    Have you tried a cable between FX send and return?
      Yes. Doesn't change anything.
        Anyone else think that bias voltage on pin 5 is a bit too negative for EL34's?
          V2 V3
          P3 488V 489V
          P4 486V 487V
          P5 -49V -49V
          P6 488V 488V
          please report also the PI tube voltages
          you also have a couple of opamps in line from the return jack to the tube,it could be some failure or simply a fractured soldering.
            i'd say to turn off an el34 you must go up to -80V
              PI voltages: p1 434v, p2 7v, p3 31.5v, p6 221v, p7 18.5v, p8 31.5v
                The resistor connected to pin 1 is most probably shorted,once replaced the voltage will be similar to pin 6
                  I suspected that too, but measured and it is 87k ohms. I will check the solder joint to that pin next.
                    reflow also pin3
                      Are both sides heater lit at PI tube position?
                        I'm with g1, it is most likely the pin 1 side of the tube is not conducting, usually because the heater is not lit.
                        I have never in my life seen a shorted resistor.
                          ......I have never in my life seen a shorted resistor.
                          Ditto!
                            Me three. Although I did see one once that had decreased substantially in resistance. So I never say never about that anymore.
                            Although I still never expect to see a complete short.
                              The only time I've come close was when I measured a 100K resistor and it measured 10K. It was while teching at a manufacturing facility. After encountering the same part problem several times, we checked the batch. It turns out the manufacturer marked a batch of resistors wrong. Still,...... they didn't short- I don't recall ever seeing a shorted resistor.
                              antalya escort
                              kartal escort
                              sex vidio
                              altyaz?l? porno
                              antalya escort
