Hi everyone, I recently picked up a Vox MV50 with a standby switching problem, I've seen this problem mentioned online in a few places, it being, when power is applied with the amp not in standby, the amp works fine, if you switch the amp into standby, then out, the amp doesn't come back up, or if you apply power in standby. This has been the reason for many people sending them back under warranty, I thought I might pick up a bargin that just needed a switch, much like Orange Micro Terrors!
On investigation the problem isn't the switch, in fact the switch itself works perfectly, all it does is switch 19v on and off to another part of the circuit.
TP12 on the middle of the picture, left hand side (+19v written above it) is switched on and off with the switch. This is in close proximity to the Ti CM053B, which is some kind of logic gate from what I can tell? The only other observation I've made is the D15 has 18 volts on the single pin side when it's working, but in the fault state this drops to 0.5v.
Has anyone on here had a poke around one of these?
