Originally posted by g1
View Post
Vox MV50 AV - supposed standby switch fault...
Originally posted by jondoe View PostThank you g1, nickb.
Those readings certainly make more sense now. I'll order up a couple of spares and get this one swapped out, it's probably toasted.Last edited by nickb; 04-19-2019, 10:59 PM.Experience is something you get, just after you really needed it.
Originally posted by nickb View PostHonestly, without a schematic it's impossible to say.
Just for my own notes, and anyone following alone at home
The 084C is tied to pins 1 and 2 of the CM0538
In normal operation the voltage reading on the CM0538 pins are
1 13.8
2 0
3 18.9
4 0
5 0
6 0
7 0
8 0
9 0
10 0
11 0
12 9.1
13 9.1
14 9.1
15 0
16 18.9
in failure mode;
1 0
2 0.1
3 0.5
4 0.3
5 0
6 0
7 0
8 0
9 0.1
10 0.1
11 0
12 1.5
13 1.3
14 1.3
15 0
16 6.48
You mean CM053B, standard like CD4052.
Supply is pin16, so either the supply is collapsing somewhere on the way, or the chip is shorting. I think you said it was replaced, so maybe it's supply is not holding up. Does it get hot when in failure mode?Attached FilesOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
I haven't replaced any of these IC's yet, although I ordered a new 084C as it was very cheap. When in failure mode the CM053B doesn't get warm in the slightest, while the 084C gets too hot to touch for long. I poured some more IPA over it earlier and noted the only other warm item is a teeny tiny SMD transistor marked "NB".
Quick update, I've swapped out the ST 084C for a TI TL084c and the fault returns. I did power it up with the IC removed and the 18v rail stays stable switching between Standby and On. Once installed the new chip heats up just the same as the previous one.
I finally got around to removing the CM053B from the board, this stopped the TL084 over heating and kept the 18v rail stable, a new one arrives this week so will pop it in and see if the fault returns. I might try and lifting legs on the IC until the fault goes away and see if I can trace the fault that way.
Originally posted by Canadiandad View PostHello. New to this thread. Just wondering if you made any progress on figuring out the nature of the fault? I have a Vox MV50 Clean with the same issues
Here are some pics of the amp http://www.voxshowroom.com/uk/amp/mv.html
It uses one of those nutube things....
I would be worried about 18.9V on the power supply for a CD4053, those cmos chips are 18V absolute maximum, so even replacing it may just damage the new one.
Is the external 19VDC power supply putting out the correct voltage ?
A TL084 or CD4053 should not run hot, there must be a short or fault elsewhere causing this issue
It cant hurt, maybe contact the vox distributor in your area, (or vox direct) say you are a service tech, and was wondering if it was possible to get a service manual, or if there was a fix for the standby problem. If the answer is no, you are no worse off, and even if you have to sign a NDA (non disclosure agreement), its still worth while.
Originally posted by mozwell View PostHere are some pics of the amp http://www.voxshowroom.com/uk/amp/mv.html
I did email Vox and ask for assistance with a repair but they informed me there were no schematics available and no serviceable parts.
