My amp was sounding OK on Wed But,today I turn it on and it didn't sound right Harsh not the normal sweet tone..I turned the bright switch on and off and it was making a loud pop, not the normal pop.I changed out all the tubes and it helped a little but I still get Loud Pop on both the Normal and the Vibro chanel Is there a easy check I can do brfore going all through grid plate test..
Old 63 Bandmaster seems alittle ill
Visual inspection of caps in doghouse, B+ dropping resistors and screen/grid resistors. How old are the caps?
Originally posted by xtian View PostVisual inspection of caps in doghouse, B+ dropping resistors and screen/grid resistors. How old are the caps?
Originally posted by dumbassbob View PostDid a full recap 7 yrs ago It was fine when I played the other day Is it normal to have a loud Pop when I turn on the Bright switch,also there is a small amount scratchiness on the normal channel volume from 6 to 10 could that coupling cap be starting to go Would both the normal and Vibrato volumes be scratchy..I need to strart at my guitar check cables too..Trying to get some ideas before I open up the hood
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by nosaj View PostScratchiness can also be a dirty pot. Try working the pot back and forth . Use your multimeter on the normal vol channel to see if there is DC there then I might suspect cap.
nosaj
And don't check for DC on the wiper with the pot at zero. Turn the pot all the way up and check at either un grounded lug.
You should be able to check for a leaky capacitor in circuit. If there's DC such that it's affecting circuit operation you should be able to see it with a meter. If the circuit is such that the downstream end of the coupling cap is also the grid of the following tube then you should check with that tube out of the circuit."Take two placebos, works twice as well." Enzo
Originally posted by Chuck H View PostAnd don't check for DC on the wiper with the pot at zero. Turn the pot all the way up and check at either un grounded lug.
