Hi,
I'm making maintenance for a Blues Deville 4x10. Voltages seems to be good all over the place but I'm having an strange behavior from the amp, a couple of times I have inserted the power tubes and one of them get hot and the other is absolutely cold and doesn't get any value for voltage drop between the center tap and the plate.
What would be the first thing to check in this case?
I inserted the tube back and then it started to work. Configured the thing to dissipate around 57% (which is cold). Then decided to check a couple of NOS power tubes because there are some noises present and then got the same problem.
Thanks.
CE
Thanks.
CE
