Plugging the pre amp into another amp shows that the pre amp is working properly. Plugging into the power in jack the sound is distorted.
Tracing from the beginning of the power amp the signal looks good through U6a and b and until the base of the differential pair and signal looks good out of Q9 and 10 emitters. From there the signal on Q11 doesn't look good but there is voltage on all pins there E 30 C -29 B 30. Should there be a clean signal anywhere on this transistor?
Where do I go with tracing from here?
Thanks
Thanks
