The idea of shielded wires connected to plates does not sound good to me, even if the shields are disconnected.
Weird howl--Marshall
It makes a lot of sense to shield plate wires (as well as grid wires, of course) as this reduces radiation of electric signal fields and thus reduces unwanted coupling.
A non-connected wire shield has no effect at all.- Own Opinions Only -
A non-connected wire shield has no effect at all.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostI was worried about stray capacitance as the fault may be due to oscillation.
A grounded shield is an equipotential surface at ground potential which doesn't radiate or couple as it doesn't carry signal voltage. It reduces stray capacitance by grounding the electric field around the wire.Last edited by Helmholtz; 05-16-2019, 11:00 PM.- Own Opinions Only -
Marshall had a couple of JMP models where they would tack the plate and grid leads side by side for an inch to an inch and a half on the chassis with goo, hot melt, or other. Plate connection of the shield has been kicked around here a few times. I haven't seen it for myself, but Ken Fischer supposedly did it on at least one TW Express. One of my designs uses a tiny capacitor from plate to grid on the input triode. Now THAT would be a more likely problem. If the cap ever failed short instead of open there would be significant voltage on the grid,.. And the guitar! At some point I'm going to experiment with just twisting the plate and grid leads together for a few turns, which seems safer."Take two placebos, works twice as well." Enzo
Originally posted by The Dude View PostClass Y cap maybe?"Take two placebos, works twice as well." Enzo
The effective grid input capacitance and the grid stopper (+ source impedance) constitute a low pass filter.- Own Opinions Only -
Originally posted by Helmholtz View PostA capacitor between plate and grid in a "grounded" cathode stage should have the same effect as wiring a capacitor having a capactance of G times the plate to grid capacitance between grid and ground (Miller effect). G is the voltage gain of the stage.
I first saw this done in a couple of Marshall models from the 90's. Then later I had a Fender Prosonic that included them in the design. The Marshall values were too high and really squashed the tone. The Prosonic used the circuit on two or three of the gain stages, which seems excessive also. My design uses a single 4.7pf cap. If multiplied by what is probably the average gain of the triode I guess that would be like a 280pf cap to ground. Sort of like adding an extra 10' of cable I guess. Except for the added dynamic element. Which is small, but does give the option some merit over a simple shunt to ground I think."Take two placebos, works twice as well." Enzo
Originally posted by Valvehead View PostChanged those wires---hum still there. I went back through the amp and checked all grounds
You've made some headway. Is there still excessive noise or hum? I've seen hum chasing go from fixing excessive hum to an attempt to eliminate ALL hum. Even in designs that are prone to a little noise or hum. That doesn't mean things can't be improved further. Just that there may be a point of diminishing returns for the effort."Take two placebos, works twice as well." Enzo
In a tube amp that can be significant with voltage sag. So when the amp is tanking voltages there's less HF roll off.
What is the stage gain difference between idle and full power in your design? Over 10%?
It's typically less than 10% for a plate supply change of 50V.Last edited by Helmholtz; 05-18-2019, 06:15 PM.- Own Opinions Only -
Originally posted by Chuck H View PostSorry Helmholtz and I are getting a little sideways on your driveway
Hum always sounds much worse in a quite room in the dead of night, on a scale of 3 to one. I had another amp that still has some hum and I almost talked myself into not bringing it to our last Gig. Turns out we needed it as the other guitarist's amp cut up the night before, and he didn't have a back up. I lent him the amp, and once we were in the Pub you couldn't hear any hum at all ! and this is early in the day. Ordinary background noise has a way of "Cancelling" out hum on it's own, it masks it.
But then there's the issue of Low Freq Hum modulating upper frequencies that doesn't sit right with me. It depends obviously on the amplitude of the hum, but low frequencies have a lot of energy by the time they are heard.
Still, there's a time to cut it free, and accept some hum in any tube amp. It makes absolute sense to me... (during the day that is).Last edited by HaroldBrooks; 05-18-2019, 06:53 PM." Things change, not always for the better. " - Leo_Gnardo
It's typically less than 10% for a plate change of 50V.I build these on a bench. I don't test them in a lab. But I'll guess that the gain difference could be 10%, but probably not more. That would seem like a lot. So the real world dynamic of the plate to grid cap would be like a grid to ground cap shifting some between 250pf and 280pf. Pretty insignificant when I look at the numbers. But there are a lot of interesting things happening in a tube and I don't doubt that voltages can bounce high as well as low. And then there's the recovery time of the filters, etc. In other words, there's enough variables in operating conditions that I think the plate to grid cap can make an audible, if subtle difference from a grid to ground cap. I don't have adequate technical knowledge to analyze it on paper well and I don't have one open on the bench right now or I'd just test it.
