There has been some discussion about this amp in the schematics forum, but I wanted to move it here to get some input. The schematics I have so far are not even close. It's a five-transistor circuit, but nothing else matches.
The input transistors are 2SB54 germanium. With the input volume turned down, the amp is initially quiet, but the hiss increases with time. I'm thinking the transistors are leaking as they heat up. The 6" Pioneer speaker sounds blown. (I hooked up a different cabinet to test.) It's hard to tell since the amp is so crappy and low power. Does anyone know where I can get a 6" speaker for this amp?
At one point, I decided to trace the circuit board and create a schematic, but the axial components are standing up. That makes them a royal pain to trace and hard to measure values in circuit.
All of the electrolytics have been replaced. That got the tremolo going. Now, it still sounds bad. That's not a technical description, but I have to do some more investigating to determine what kind of distortion I'm hearing. It's not flat topping. The low frequency response is terrible below 200 Hz, but I don't know if that response curve is intentional. I've never seen one of these amps working, so I have no point of comparison.
Any thoughts welcome. I'm not charging for the repair, so it's educational at this point.
