Looking for help with my just acquired 5005 combo. Sounds anemic; low and fizzy output.
This amp was built in 1984. Not sure the schematic attached is the right one, dated 1986.
I have + and - 18.2 VDC on the rails.
IC1 pin4 is -14.6 VDC, pin 8 is +14.8 VDC. Other IC1 pins have nominal readings in the low mVDC area.
Also getting a lot of intermittent squealing sounds.
I have checked all solder connections on the bottom which look good. Cleaned all the pots and jacks.
What do you think? Where to start?
Thank you. MarkO
Thank you. MarkO
