Hello everyone,
I'm trying to repair this amp that stopped working producing smoke.
You can find the schematics in the attachment.
Inside, I found the TSI (Tube Status Indication) circuit badly damaged and partially carbonized. There's actually a hole in the PCB, due to excessive heat and probably flames; one smd resistor is destroyed and other components are blown.
I will later point out all the damaged components on the schematic, if necessary.
I also found another damage at the output stage:
Two of the four 1.5k grid resistors were burnt as well (R38, R39).
These resistors are receiving the signal from the plate of the phase inverter tube, so I suspect C7 has started leaking, compromising the output tubes BIAS, and causing all the issues to the TSI circuit as well (please tell me if I'm in the right direction, here).
I replaced this cap with a new, 630V rated Mallory capacitor; I don't know how to test the old one: it is not visually damaged, and measures the nominal capacitance on my capacimeter. I should test it under high voltage, but I don't know how to properly do it. (Do you have any suggestion?)
I've also replaced R38 and 39.
Now I would like to try the amp, but I definitely need some help.
I would like to bypass the TSI circuit, and I think I will remove some components from the PCB, in order to isolate the TSI circuit, but I'm not sure about the output stage.
Do I have to remove/bypass the polyswitches on the cathode of the output tubes? Or can I safely leave them there?
Out of curiosity, ...what do you think of all the (over)complicating features of this amp? Among others, there's an output power switch, a speaker enable/disable switch, and of course the fabulous TSI system.
Thanks a lot,
Cristiano
Thanks a lot,
Cristiano
