Hello folks,
I searched a bit for any info on the board for this issue & it looks like this one is new.
The space echo has flutter in the speed of the brushless motor under load. With no load ie; pinch roller disengaged, the speed of the motor is consistent.
When the motor flutters, it does cause voltage loading , ie the meter bulb flutters, too.
The motor runs simply by hall type position elements & really no servo to speak of. Normally the drag on the motor is mostly from the pinch drive as the tape presents very little drag.
I cannot determine if the issue is work bushings in the motor causing excessive drag when the pinch roller is engaged or if it's the circuit that is having difficulty driving the motor.
If I load the motor with just my finger to take the pinch drive out of the picture, the bulb still shows fluttering, so I don't think the pinch drive is the culprit here.
Does anyone have any experience with this issue? I seem to recall a site I visited a few years ago where a guy was claiming to be quite the whiz on these units up to providing 'rebuilt' motors...can't find it now.
Thanx, glen
Thanx, glen
