Here’s a link to the schematic: https://images.app.goo.gl/mMEAbXUnVScHQXwu8
There are ceramic disc caps in there, one of them was badly noisy and was replaced, besides freeze spray, none of the other suggestions bore any results. So from everything I know, I can confidently say it’s not a grounding issue. There is however about 6vDC leaking onto the treble pot and I can’t really track down where it’s coming from and the first preamp stage is very microphonic when tapping on the tube, maybe something to do with the first two stages being cascaded? The voltage looked higher than it says on the schematic. Says plate voltage should be 140 but it’s more in the range of 192
