Schematic:
https://www.thetubestore.com/lib/the...-Schematic.pdf
First, a couple filter caps were bad. I replaced all of them.
Next, the vibrato didn't really seam to work until intensity was on about 4. I replaced the Opto. and while in there, I changed the two .01uf caps to .02uf to slow it down a bit. Thats when I noticed the hum. I thought it might be the new bug I put in, so I put the old one back in. It was still there, just not as much. That is because when the new Opto. was in, it worked better and made the hum stronger. Speed knob changes the hum, but intensity does not. Reverb knob adds hiss to it.
The owner did the mod where you remove R12 and run a jumper from R25 (to give reverb and Vibrato to both channels)
60 hum/buzz is coming through when vibrato is on. I started pulling tubes V1, V2, V3 no change. If I pull V4, it goes away. Also, While signal tracing, I found if I touch V5 pin 1(or components that are at the junction) It stops. Oh yeah, touch with the probe (not my finger heh) . I tried different tubes, re-soldering parts, moving the few wires, there are, around.
Also, If I touch V5 pins 2 and 7 it mostly goes away.
It worked putting a cap from V5 pin 1 to ground. Any ideas, or should I just go with that. And, if so, what value cap? I had a .047uf death cap from an old vibrolux I tried.
Thanks,
Kirk
Thanks,
Kirk
