Hi all,
I just finished working on a Fender Blues Deluxe Reissue (new filter caps, rebiasing to factory spec). I'm sending a 1khz sine wave into the power amp input, and this is what I get on the scope:
![Click image for larger version
One side of the waveform is clipping much sooner than the other. If I flip the power tubes, the top of the wave clips early instead of the bottom.
Is this a case of mismatched tubes? Is this expected in tube amps? Is this considered normal operation, or is there something else I should be looking at?
Thank you!
Matt
Thank you!
Matt
