I just fired up a new build, it is a variation on the 5E3X2 where I grafted a 6AU6 pentode into the preamp as the first gain stage for one of the channels (the chassis had an extra socket hole, so I decided to experiment a little). I'm getting serious scratching on the guitar vol/tone pots, and I found about .8vdc on the input, which seems to be coming from the heater circuit as I've got the voltage with the amp on standby. I pulled the tube and the voltage goes away but comes back when the tube is reinserted. I tried 3 different tubes and they all give the voltage on the input. Any ideas why? The grid connects to pin 1 and the filaments are on pins 3 & 4, I see no fuzzies or solder blots or anything connecting either of those pins.
I could use a cap to block the dc from the guitar, but this seems like a bandaid approach. I'd like to get rid of the dc if possible.
Note that the 12AX7 channel has no dc and no scratchiness on the guitar controls.
Besides this problem I need to do a little sorting out, but this is an interesting sounding amp, the tone and gain are very interesting. Once sorted I think I'm going to really like it.
Edit: wait a minute, filaments are ac, that couldn't be the source of the dc voltage on the input. But in Standby all the DC is cut off. hmmmm...
