I know there are a number of posts made on the HRDR due to a variety of problems. I had some severe distortion/oscillation on all channels and replaced the 3-22uf caps and the 47uf filter caps with some F&T's and that stopped all the problems with the exception of the inability to engage the drive channel. When I push the drive button, the red led comes on, the drive volume works in conjunction with the master volume but it doesn't get 'dirty". It just stays clean.
I've ran the 12ax7s thru a tube tester and they all test fine. Would this be the drive button or one of the relays and if so, which one is the likely culprit?
