Hi.
Thanks to the help of several members, I was able to get my bias properly checked and now facing a new challenge.
2000'ish Marshall 1959SLP (the pre-fx loop version) reissue.
The amp was in somewhat poor shape when I got it, just getting around to making some repairs... had some nasty IMD (ghost notes), bulging filter cans, tube sockets that seemed to disintegrate when pulling out a power tube etc.
I replaced all filter cans (6 dual cans) and while I was in there I replaced all signal caps with Synergys and a few Sozo (yes, I am one of *those* guys). In addition I replaced all of the power tube sockets.
The original heater wires were incredibly thin, so I replaced them at the power section as well. The original filter cans were all ARS 50/50 500VDC and I replaced them with the same (sourced from Watford in UK) values, also ARS.
And other than replacing the two 56k resistors in the power section as well, all else is as it was.
Started it up again today after finishing those repairs and certainly the overall tone for me had improved, but the IMD is still there and now there is a added hum :-(. Here is an audio clip - in the first few seconds you will hear the hum... then a few seconds of high notes to "feature" the ghosting.
MARSHALL_1959SLP_IMD.mp3
I will also attach some photos of the chassis, perhaps you see something I do not? A few circuit changes (small)...
Changes: The reissues weren't exactly traditional values. In lieu of a .0022 decoupling cap on v1b, there were a few in parallel. Same with the bright cap on channel 1. So I simply returned them to traditional 1970'ish values. C15 and C16 replaced with a single .0022 and C17 and C18 replaced with a single .0047 and moved to the actual volume pot.
I pulled the 4x 68k resistors out of the signal path (just clipped the wires) and attached some 68k metal film resistors at the input jacks and ran shielded cable to v1a/b.
So what are other common reasons for ghosting notes? I have read all sorts of things from output transformers to chokes to "it's part of the marshall circuit" - however this isn't the first superlead I have owned, yet the first time I have ever heard ghost notes... it took me weeks to determine that is what it was.
Thanks!
Thanks!
