I just retubed a Marshall head that came to me with Sovtek 6550WD in it with the sockets tied pins 1 and 8 together. These tubes will pull as much as 75 - 90 mA with the bias turned full down. I put new JJ EL34s in it, but the most I can get out of them is ~ 18mA/ea. I tried another set, and same thing. I notice on the 6550s pin 1 has no connection, with cathode and supressor grid tied together internally. With the JJs pin 1 is supressor, and pin 8 is cathode, tied together at the socket. Wouldn't this essentially be the same thing electrically?
Why are my EL34s pulling so much less current? The schematic shows EL34s, not 6550s. Also, the schematic shows a 56K bias supply resistor, this amp has a 47K in that spot.
https://www.thetubestore.com/lib/the...tek-6550we.pdf
https://www.jj-electronic.com/images.../el34_e34l.pdf
https://www.thetubestore.com/lib/the...-Schematic.pdf
