Adcom GFA-555
  • Adcom GFA-555
    Hey guys,
    Working on an Adcom GFA-555 power amplifier. It cut out, and after opening it up i found a burnt R21. I replaced that, and then checked around for shorts. I ended up replacing Q17-Q20, with MJ21194 in place of the 2SD424. Also replaced resistors R24-R27, and the driver Q12. D2 diode tests fine. Powering it back up i;m getting some incorrect voltages. My +/- supply is 75/-75vdc. Once i get to D2 however, i'm getting -73vdc on the other side of it, instead of the -55mV that i'm getting from the working channel of the amplifier. It would seem to me that Q12 is at fault, but it appears to test okay. Any ideas of where i should be looking?
    Adcom-GFA-555-Service-Manual.pdf
    You may be better suited for response by posting this in the Music Electronics forum rather than under Guitar Amps.
      Just saw that. Thanks Randall!
        Look further back, like teh driver transistor, and of course check all associated resistors. Resistors often burn open when transistors short.
        And really, you might have more success over at www.DIYAudio.com forum.
