SWR SM900 Fan Circuit issues (older series)
  • SWR SM900 Fan Circuit issues (older series)
    Having opened up a client’s older SWR SM900 amp, the 2-pair quasi-comp output stage variety (four 2SC3265 Sanken MT200 pwr xstrs) and having the larger single EI power xfmr, I found the rear heat sink assy (right channel) had significant burn damage throughout the module. After initial clean up with alcohol, then removal of the power xstrs/PCB from the heat sink, and then removal of all the failed xstrs & burnt resistors, I scrubbed the PCB further to reveal major charring of the PCB on the upper half of the output stage, both sides of the board, and only a few small signal xstrs remaining unharmed, while surprisingly the 0.1 ohm/5W emitter resistors of the output stage were intact. The damage was severe enough to motivate me to see if I still had one remaining power amp module in a boneyard SM400 chassis. I did, though that module had an earlier PCB layout than the pair in this SM900. Mainly what was missing on the right ch module removed from the SM400 was the turn-on/fast-off circuit that runs the front end of the amp circuit, and was easy enough to extract, part by part from the other module that had been cannibalized before to yield what was needed for a replacement module.
    I powered that module up outside the chassis with an external dual-tracking lab supply to verify basic operation and to set the bias. Then, transferred it to the chassis and installed it. The other amp module (left ch) had a bulging 1000uF/35V buss cap on the fan circuit, which I replaced. I also decided to install the 300 ohm/5W slow speed fan resistor on that left ch module. When I powered up the amp, I found the DC fan was just pulsing, trying to turn on, but not getting there. The voltage at the fan was about 5VDC. I removed the 300 ohm resistor, replacing it with a 100 ohm/5W resistor, and tried again. Still had the same pulsing behavior on the fan at start-up. Reaching in with EZ-hook jumper cable, I shorted the TO-220-case Thermal Switch, to see if the fan would run, and what that voltage was. 11.3VDC, and very low velocity. THIS is FULL SPEED???!!
    I removed the left ch module to see what the fan was. A Mechatronics 24VDC fan (didn’t record the model #). I looked to see what the AC voltage was feeding this half-wave rectifier circuit on the module. 23.6VAC, with the other wire to the fan circuit tied to chassis ground. I don’t have the power xfmr schematic, but looking at the wires leaving the secondary, there’s the power amp’s HV bipolar winding with C/T (red-red-red/yel), a HV winding (vio-vio) to run the tube plate voltage, a heater winding (grn-grn) and a red/wht lead, which I assume to be a tap off of the power amp supply winding, used to run this half-wave rectifier circuit for the fan.
    I tried adding an additional 1000uF cap following the 100 ohm resistor to charge that fan voltage up a bit more. It was barely enough to get the fan started, but got it past the pulsing behavior I had without it. Time to break out the scope probe and current probe to see what’s happening.
    Before doing that, I went back to that boneyard SM400 chassis to extract it’s fan, which was a Nidec TA-300DC 24VDC fan. I unsoldered the chassis’ 24V fan and connected this Nidec 24V fan. And, then connected the scope probe at the rectifier/filter stage, and the current probe across the AC tap running this circuit. I left the additional 1000uF cap in place, as it did help, though increased the initial inrush current.
Name:	Power Supply start-up-1.jpg
ID:	874825 Click image for larger version
Name:	Power Supply start-up-2.jpg
ID:	874826 Click image for larger version
Name:	Power Supply start-up-3.jpg
ID:	874827 Click image for larger version
Name:	Power Supply start-up-4.jpg
ID:	874828 Click image for larger version
Name:	Power Supply start-up-5.jpg
    That inrush current was found to be in the 8-11Amp peak current, dropping immediately to around 4A and lower, as the filter(s) charged up. I haven’t looked at the current behavior of 1N4002-4008 class diodes, but, with that additional 1000uF cap, we’re getting a lot of current pulsing thru that single half-wave rectifier. This ‘stock’ circuit is a joke!
Name:	Power Supply start-up-6.jpg
ID:	874830 Click image for larger version
Name:	Power Supply start-up-7.jpg
ID:	874831 Click image for larger version
Name:	Test Set-up-1.jpg
    Even with a second cap, and a lower value ‘slow’ speed resistor added, the thermal switch shorting that out to put the fan into ‘high speed’……is only a 2VDC change. With the fan then running at 12VDC, maybe 12.3VDC, hardly anywhere near the velocity needed or what a 24VDC fan COULD provide in this amp. As neither of these heat sinks have any high temp cutouts to shut them down, I suspect it is this pitiful fan circuit that allowed the full flameout / melt-down of the one amp module. I did verify the TO-220 style thermal switch works, having activated it with that new GJ-8018LCD Heat gun / small nozzle shown in the set-up photo.
    I thought about maybe using a 12VDC fan instead of the 24VDC fan, but…..looking at the start-up characteristics the fan sees for the first couple seconds, AND, I’d be pulling twice the current thru that diode, I’m not sure that’s a good solution, though at least it would get the proper CFM flowing to cool the modules. Maybe cobbling together a voltage-doubler circuit to run the 24VDC fan? Not without that circuit creating rating issues on the filter caps and the 24VDC fan, until everything stabilizes, no doubt. So, what IS the solution? Put it back to stock, close the lid and send it back, as these amps have been running that way for years, haven’t they? Sometimes ya never want to know the details.
    SM-900 (Post 1997, Complete).pdf
    The attached SM900 Schematic shows both this 2-pair quasi-comp amp module as well as the next generation fully-comp 4-pair output stage modules, with a fan circuit there that DOES work, though still using a 24VDC van, still won't get to full 24VDC potential, that I recall. I don't have one on the bench to verfy it. In that model, there are TWO fans, each using that variable-speed fan circuit and a thermistor to control it.
    I believe I have a pair of those power modules, removed from working equipment. PM if you have any interest or need for such.
      Everything changed when Ch 1 Heat Sink was screwed onto chassis!
      After removing the Nidec fan wires, and removing the temporary 2nd stage 1000uF filter cap, I shaped the leads of that cap, added a touch of RTV to glue it into place, soldered it in, then re-soldered the installed Mechatronics 24VDC fan wires, and then installed the four flat head heat sink screws from the bottom of the chassis. Hooked up the voltmeter across the fan wires/1000uF cap (2nd stage filter), and powered the amp back up.
      To my surprise, the fan voltage at this 'slow speed' was now running at 19.4VDC, and jumpering over the thermal switch for 'high speed', the fan voltage jumped up to 28.7VDC! Huh???!! All this as a result of screwing the heat sink back into place?
      I don't have the charred PCB here at home with me, so I can't see if there is a path from the ground of this fan circuit to the heat sink off the PCB....I don't think there is, and, I don't see how that would make any difference anyway, but...............this before-wimpy fan circuit is suddenly solid and working as I would have thought it should be.
Name:	Power Supply start-up-gnd'd heatsink-1.jpg
ID:	854491 Click image for larger version
Name:	Power Supply start-up-gnd'd heatsink-2.jpg
ID:	854492 Click image for larger version
Name:	Power Supply start-up-gnd'd heatsink-3A.jpg
ID:	854498 Click image for larger version
Name:	Power Supply start-up-gnd'd heatsink-4.jpg
ID:	854493 Click image for larger version
Name:	Power Supply start-up-gnd'd heatsink-5.jpg
ID:	854494 Click image for larger version
Name:	Power Supply start-up-gnd'd heatsink-6.jpg
      The first photo shows the peak current flowing thru the half-wave rectifier circuit, into the 1st stage filter, 100 ohm resistor & 2nd stage filter & 24VDC fan, with scope probe at the 1st stage filter. I changed the current probe deflection to 5A/Div, this showing 9A peak current on that first cycle, then dropping steadily. Now, with just mounting the heat sink, the fan has proper voltage and velocity to force cooling air thru the heat sink fins.
      I didn't take a finished photo of the fan circuit end of the module.....though the only difference is re-positioning this temporary 1000uF/35V cap, laying it down with a spot of RTV glue to hold it into place, still having it across the 24V DC Fan, fed via 100 ohm 5W Metal Oxide resistor.
Name:	Test Set-up-2.jpg
      Why would mounting the heat sink change this? The fan circuit is isolated, but with connection to chassis ground, independent of the heat sink being mounted.
      Enzo, I may contact you on those 'spare' amp modules as the need occurs. At the moment, this amp is back together, though we have a number of these modules in our SM900's, as well as in the two Mo Bass amps, and a steady client whose amp this is has more of the same, so good to know you have those. Thanks!
        At your leisure. Unlike many other things in my storage units, I know exactly where they are and I can reach them.
          This morning, after looking at the companion PCB that had burnt thru the fiberglass, I found the fan circuitry is completely isolated from the heat sink. The head of the corner screw adjacent to where the ground wire is soldered (from chassis solder lug) to the ground of the fan circuit is pretty close to the pair of solder pads, but, the trace joining those two top pads is on the bottom, and the standoff is nylon. I added a small split lock washer under the screwhead just to elevate it to be sure. With the heat sink lifted off the chassis, there is NO continuity between ground and the heat sink.
          I measured the current thru the ground wire, and saw the same current as on the AC wire feeding the rectifier diode. And, today, unlike the first time around, with the heat sink unmounted and isolated from chassis, I was getting full fan speed, and not the very low voltages found on Wednesday. So, I am without a clue here. At least the fan circuit is running ok again. I am a little concerned about the peak repetitive current flowing thru that 1N4002 1A rectifier diode. I know they can handle the inrush high current peak, which I've seen in the 8-11Amp range, non-repetitive (drops rapidly to steady-state). I didn't get any insight reviewing the two 1N4001-4008 data sheets to make me want to change to a higher current diode. I've never seen one fail in the SWR fan circuits.
