Originally posted by Helmholtz
View Post
LTPI little help, please.
Last edited by catalin gramada; 08-12-2019, 07:01 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostWhat is surprising for me,with 12au7 clip relative hard . Why ? The outputs are quad of el34 triode strapped into 4 ohm load resistor.
Put some pics with output and PI output scooped together. No nfb was used.
Is something you don't want to use for guitar, I guess...
[ATTACH=CONFIG]54673[/ATTACH]
[ATTACH=CONFIG]54674[/ATTACH]
I suspect EL34 grid conduction, meaning that grid drive voltage is too high for the circuit. This would show in clipping of the positive peak of each PI output.
What is your bias voltage?
Can you show a schematic of the complete power amp?
How does the PI output look with power tubes removed?- Own Opinions Only -
Thank You.
The first pic show the signals at onset clipping. Yellow-OT output on 4 ohm load, blue-output of inverted PI section (PI outputs are reversed to can acomodate eventually nfb in cathode resistor of gain stage before pi) Bias voltage is 43V and was arbitrary choosed for cca 70% plate dissipation (not sure if quite right in triode mode)"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by Helmholtz View PostThis means you will get clipping by grid conduction as soon as the grid signal amplitude exceeds +43V.
Two question please: why is happen that, and how can be solved? A big value grid stopper help, please?"If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Large grid stoppers may somewhat smooth out the hard clipping.- Own Opinions Only -
Originally posted by Helmholtz View PostIt happens because the grid-cathode path acts like a diode. As soon as the grid gets more positive than the cathode, the diode is forward biased and starts conducting current. This in turns loads down the positive going PI signal.
Large grid stoppers may somewhat smooth out the hard clipping."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
Originally posted by catalin gramada View PostYes,yes this is clear but asked why is happen to have this hard clipping characteristic? It looks almost as SS one.Never seen to clip so hard identical tube in almost identical conditions in pentode mode. It is somehow related to triode strapped connection?
Also pentodes have higher internal plate resistance than triodes which also makes clipping smoother.- Own Opinions Only -
Given the direction this thread has taken, to avoid a whole lot of possibly incorrect assumptions being made about the amp in question, a full power amp schematic is essentialMy band:- http://www.youtube.com/user/RedwingBand
Yes,You,re right pdf64. Till now no schematic, just a plan. I still try to understand how to do EL34 usable in triode mode, after some times ago had a very deceptive experiment with kt88, or 90...don,t remember...
Anyhow el34 seems to be a good candidate. My goal is to provide a very good damping factor with minimal amount of nfb or not at all for a bass geetar aplication. I don't have to many options around here ,so I used what I have on hand : hefty 480v supply , with 200uF filter cap. 1.9k OT(not quite optimal load) and a quad of Russian el34. Keeping toped at 480v - no problems, screen grids was tied to the plate with a 100ohm resistor to prevent osscilation ( no really think it need it) . Power dissipation over screen was max 5w in hard clipping condition. ( datasheets states 8w max). I found it sound way better with g3 disconnected from cathode, so I keep that. The power at onset clipping with 1.9k into 4 ohm load was 70w, 24Vpk.not bad.. Just for those hard clipping I cannot decide. Maybe it sound still usable, which I doubt, but had not possibility ti crank it in my basement yetLast edited by catalin gramada; 08-16-2019, 01:56 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
