I'm repairing a friends amp (he said it's a 2003) which seems to be clipping more at normal volumes. As with other posts here, I found that there were some bad solder issues with the power tube sockets but I believe I fixed them. I've noted all the DC voltages but I can't find the expected VDC's anywhere on the schematic for V4 & V5. I also found that V2 pin 1 was 0, which can't be right since it's the plate & V1 pin 1 was 172. Both sides of V2 checked out as borderline "good" on my tube tester. V1 & V2 voltages were good.
Another issue is my friend replaced the original with a Vintage 30 speaker. I believe the original is 50 Watt.
1. What should V2 pin 1 be?
2. What should V4 & V5 pins 2, 7 & 9 be?
3. Is the Vintage 30 a bad choice for this amp? Too under powered?
Btw, I noticed that there are alot of AC measurements in one of the schematics. Is that to be done with an injected AC signal & is the reason to find a possible problem in the AC path?
