The old output tranny was toast. I substituted a dual showman output tranny with alligator clips temporarily to see if I got an output, and did with normal waveform. Bought a new output from Peavey. Mounting bracket didn't fit all the holes (just two). Had to cut the wires since the cable plugs wouldn't go through the chassis holes. Double check color codes. Turn amp on AND... WHEEEEEEEEE!!!! High pitched whine oscillation noise crap. I'm going to see about sending this tranny back if they will take it. What y'all think?
Peavey classic 30 output trans. Replacement bad?
