Aloha from Hawaii all..
My beloved DSR was down & I finally got around to working on it. There was no audio, but not blowing fuse/all tubes glowing. Long & short of it turned out to be no B+4 (~400VDC). It was getting knocked down to 9+VDC. I began to trace out the circuit & lift B+4 off at each point it connected to preamp tubes and then voltage returned at each point until I got to V4. No matter what I tried, removing and testing components,as soon as I reconnected B+4 to V4 (2 100K 1W resistors) it got knocked back down. So, I was just about to post here and ask for advice, when I remembered other times when strange things happened as a result of the fiber & turret boards' being so close together. So I decided to unscrew & slightly lift up the turret board & prop it up & VIOLA! B+4 was back (300 some volts) and amp fixed..I used it last night! Yep one for the ages!
