Schematic ->Trace-Elliot Commando Bass Service Manual.pdf
Hi all, I have one of these brutes in bits at the moment, it had fried both the TIP35/36 output transistors, I've replaced them with good quality parts and it looked fine on a dummy load. When I placed the amp back into the chassis and wired up the existing speaker driver it was OK at low volumes but when I cranked it up it crackled and farted, I turned it off and one of the mosfets was pretty damn hot. The DC resistance on the original driver is a rather low 1 Ohm, although i can't find the original spec of it (no useful label) this is way too low, did the dying fet's fry the original driver?
I've rigged up an 8ohm junk driver and it runs it well, even at high volumes, the fets barely warm up, but it does seem to put out a reasonable amount of DC when powering up, the cone rises sharply before returning back to a resting position for about half a second, is that expected? I've read conflicting accounts of this being the norm on some older style amps, I was wondering what your collective thoughts are?
thanks
thanks
