I have an Ampeg SVT CL Classic on the bench. Owner tried to replace 10R bias sense resistor, but amp would not come off standby.
I repaired his botched job; now all 10R resistors (R35-40 on schematic) and surrounding circuit measures correctly for circuit continuity through the J11 jumper to the tube PCB.
When I turn on the amp in standby mode, the tubes all light up, the power LED is red. When I switch out of standby, the LED goes dark, and the heaters in all the tubes go dead! It's like the standby switch is a heater switch! The bias LEDs on the back panel never light up.
I cannot see anything on the schematic that would suggest why the heaters go dead when I flip the standby switch. Ideas?
http://www.bustedgear.com/images/sch...peg_SVT-CL.pdf
