Hi there-
I have a Blues Deluxe Reissue from 2017 that has a strange problem in the negative bias circuit. I searched the forums and found a thread from 2012 where someone seemed to have a similar problem, but their's was constant not intermittent, and it wasn't totally clear if they resolved the issue. (https://music-electronics-forum.com/...es+deluxe+bias) Other than that I can find little-to-no info about this anywhere on the web.
My problem is much like the one in the above referenced thread. I too see around -105V at pin 5 of the power tubes, but only intermittently. Always at start up, never cuts out or changes if it successfully turns on.
I also have a negative bias circuit that does not match the most recent available schematic (2014, REV A, page 2 (https://www.thetubestore.com/lib/the...atic-Rev-A.pdf). I have contacted Fender in an attempt to see if they have a "REV B" or some circuit update, and the customer service rep told me he didn't have access to anything newer than REV A.)
Specifically, the negative bias supply has C37 and D10, which should not be in the Deluxe. Also, some values are changed. C37 and C43 are 47uf/160v (should be 100uf/100v), R76 is 82K (1.5K in Deluxe, 10k in Deville), and R77 is 68K (should be 100K). R83 is not installed.
It has the proper power transformer for the Deluxe with the two brown wires, no center tap.
So, that finally brings me to my questions:
1) does anyone know anything about this circuit change? Is this the new normal? If so, is there any sort of schematic/docs regarding it?
2) anyone have any idea why this newer circuit might fail, permanently like the above referenced thread, or intermittently like the one I am looking at?
3) anyone have any idea why this circuit might be better than the one on the schematic? And,
4) is there any reason not to put it back to the wiring on the schematic? It seems to double, then divide the voltage. Any reason to just not double it?
Thanks in advance for any insight anyone is able to offer.
