I have this unique Analogic 2030 Waveform Synthesizer which has a large LCD screen on it's front panel which has horizontal lines across it that don't belong. This is the last of the three units I had owned, having repaired and sold the other two back in 2011 & 2012, keeping this one, having finally succeeded in repairing the power supply. The instrument IS functional......just has these unwanted horizontal lines appearing on the screen and thus far, I don't know if this is a permanent defect in the display, or if it's from the controlling circuitry or even connections. When I was first investigating this, I still had one of the one other instruments, and swapping screens, the problem moved with the front panel / screen PCB assembly. That may rule out interconnects, as far as two instruments were concerned. Still could be connector issues on the defective screen assembly.
Anyone out there with experience on troubleshooting LCD screens like this? I do have the service manual, though the reproduction quality is pretty poor. Analogic hasn't been in the Instrumentation business now for a good 10 yrs or more, so no replacement parts available nor factory support.
![Click image for larger version
I had dialed up a Phase Modulation waveform, using 50Hz @ 1V RMS (1.414V Pk), with 45 deg Phase modulation at a 4Hz rate. Scope photo shows the modulation character. The last image shows what the LCD Display should look like....this one being from one of the other instruments I had sold.
Name: FTRV-Open for Svc.jpg
Analogic _2030_Data Sheet.pdf
