Hello again guys, nice to see this helpful place is up, running and full of nice people
I already posted here a problem with this damn C30 a few months ago, though you probably don't remember me. But anyway.
The problem can be described quite shortly - when turned on, the thing sqeals instead of properly amplifying my guitar signal
No guitar sound, just high pitch oscillation plus the usual little hum. The frequency of oscillation is decreacing during time, though I never ran it longer than 3-4 seconds. I've figured out the problem is after the preamp - it's not affected by any pots, it's still there if i insert a cord into the return jack, and the sound picked up from the send jack is fine. But the amp is silent if I pull the phase inverter out. Swapping 12AX7's around doesn't solve the problem, so it's not the V3 tube.
That particular amp had some soldering flaws around the power tube sockets, so I had to disassemble it a few times to resolder. One time after resoldering it started to work like this: 15mins of normal working, and then it cutted out and developed a faint oscillation, with frequency going down slowly. First minute after that it looked completedly like a bad leads connection/soldering joint - it cutted in/out if i moved the amp a little. Next it died out completedly. If turned off and cooled down, the amp began it's thing from the start - 15 mins running normal, then dying out etc.
After two times of disassembling/assembling in effort to sove the problem, the amp started to act as said previosly - just loud oscillation right from the start.
There's nothing bad looking on the board, no bad smell and all the jumpers are allright, so there's totally nothing I could suspect. I don't have the oscilloscope. The circut boards are facing each other when the amp is assembled so I can't even use a chopstick. Damn thing drives me insane, it probably spent more time disassembled and being repaired than actually working. I don't have much free time so now it's not working for, like, month and a half.
Please help me locate the source of a problem.
Cheers.
Cheers.
