Hello all
I’m looking at a 1967 Super Reverb that, when you play it hard or turn it up, it has ugly distortion.
It happens on both channels.
Sending the sound to a different speaker cab has no change.
I’ve cleaned and retensioned all tube sockets.
I’ve swapped in known-good tubes for all the preamp tubes, one at a time,no change.
While turning the Amp on and off during the preamp tube swaps, the rectifier arced and blew the fuse.
I’ve replaced the rectifier with a brand new Tube Doctor 5AR4.
Poked around inside the Amp with a chopstick while it was live, no apparent bad solder joints or broken/burnt components.
I’ve replaced the power tubes with brand new Sovtec 6L6GCs.
Bias of the new power tubes looks good at 37mA and is even at both tubes.
The Amp was serviced in 2011. It had the power caps replaced with a full complement of Spragues.
The bias cap was replaced then as well, and also the resisters on that little board.
The 100K resistors that tended to make that “sizzley bacon frying” sound were also all replaced at that time.
All of the other components are original.
Has anyone else in their experience had this situation?
I have to think that the problem is closer to the output...I haven’t tested the speaker jack very closely but I have cleaned the contacts on it and all jacks and pots
The Amp has been actively gigged since it had the service in 2011. It’s my sons amp so I know it was gigged locally and also been in and out of cars and clubs like 20 times a year.
http://ampwares.com/schematics/super_reverb_aa763.pdf
Thanks in advance for your thoughts
Earache
Earache
