So, I've just figured out that the wire running from pin 7 or V2 on my SF Pro Reverb is corroded and is likely causing a low output situation on the vibrato channel. My question is, what kind of wire is being used and what are some possible types of replacement suitable for this application?
Corroded wiring in a SF Pro Reverb
Corroded wire?
There is no special wire in these amps. About the only thing I might consider special would be the occasional piece of shielded cable. Is that what you have? Otherwise, plain old hookup wire. Ther is no appreciable current into a grid on a 12AX7, so the wire gauge doesn't matter. No point in large wire so 20-something gauge is fine.
I wouldn't generally suspect a wire for a low output condition.Education is what you're left with after you have forgotten what you have learned.
Thanks for the reply. I've uploaded two pictures of the wire the one is the end that connects to the 1m potentiometer and the other picture is the end connected to pin 7 of V2. If you look closely at the first picture, you can see what I believe is corrosion in the wire strands.
Replace that wire if it bothers you, or trim it back a bit and re-strip it if it will reach, but I suspect it is not the only wire like that in your amp.
This is what I use, it's nice and I like this distributor as well. https://www.markertek.com/product/23...black-per-footLast edited by Randall; 09-29-2019, 10:54 PM.It's weird, because it WAS working fine.....
Originally posted by Randall View PostReplace that wire if it bothers you, or trim it back a bit and re-strip it if it will reach, but I suspect it is not the only wire like that in your amp.
Thanks for the link, Mogami is really useful in SF Fenders.
Zouto
Originally posted by Sleet View Postis there a particular reason Fender chose this type of wire for use with volume controls? The master volume on this amp also uses this type of wire. It seems to be a shielded cable of some sort.
What I do find in Fender's shielded cable from that period, the inner insulator melts very easily, also is discolored grey. When re making these connections, I put a piece of heat shrink over the inner insulation layer, tends to hold things in place.
Good lead Randall on the Mogami ! Very affordable, and Markertek isn't far away from where I am. Might have to invest in a 100m roll of this stuff.This isn't the future I signed up for.
