Well all heaters are lit that’s about as far as I’ve gone. I typically do fenders, I’m just learning Marshall stuff a little
Marshall JCM 800 50W
Originally posted by pnut5150 View PostYes sir that is the correct transformer I have.
The old transformer somebody had hooked up was smoking when powered up, when I unhooked the 0v B+ wire it would quit smoking and the lights would come back on bright. I don’t want this Mercury to smoke lol.
But first make sure you use the correct mains fuse and that your filter caps are ok. In case of doubt use a bulb limiter.Last edited by Helmholtz; 10-08-2019, 05:26 PM.- Own Opinions Only -
Ok we are getting somewhere now. The mains fuse they had in it was HUGE!! With yellow wire going to pin 4 on power tubes from the first 50uf 500 cap removed the amps stays on, that wire has 360v, so I’m assuming that cap is shorted out internal? No swelling or bulging
1) If you suspect a cap is shorted, check it with your meter.
2) Pin 4 of power tubes is the screen grid. There shouldn't be a wire going directly there. It should be going to the screen resistors.
3) If the wire going to the screen resistors is the one you unhooked, the caps are still connected, so a shorted cap wouldn't be the problem. It would likely be tube(s), wiring, or socket(s)."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
I do have 360v AC across the two red wires with the red/black to ground.- Own Opinions Only -
Originally posted by The Dude View Post1) If you suspect a cap is shorted, check it with your meter.
Well, then there's obviously a short or heavy current draw downstream from the HT fuse. Do you have a light bulb limiter? If not, now's the time to build one before you damage something else in the amp. I'd first try removing the output tubes and see if the LBL glows bright. You could simply have a shorted tube. Is your bias voltage there? If bias is missing, the amp is going to draw a hell of a lot of current. Again, remove the tubes and see if voltages return to normal."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by pnut5150 View PostI don’t have a limiter...
My view is that for jobs like this they are as essential as a functioning multimeter.My band:- http://www.youtube.com/user/RedwingBand
Originally posted by pnut5150 View PostI guess I can find schematics or diagram online to build one?
There's something on robrob's site too, his wiring diagrams are usually nice.My band:- http://www.youtube.com/user/RedwingBand
Figured I’d follow up on this thread, been busy hadn’t had much time. Turns out the problem was the capacitor I was concerned with. One side was shorted out. It would flash out my capacitance meter when measuring that side. So new Mercury PT, (2) F&T caps and new tubes and resistors and she’s back to life. Thanks for the help guys
