Crate G-212
This comes on, power amp seems ok, had a thump when powered up, some controls made static with reverb, it won't switch off of channel A.
It has been extremely hot around the zeners just after the drop resistors on the preamp board, I figured out one was backwards, reversed it, and now the negative rail has -17 at the drop resistor, but the positive rail is only 3v, but goes up to 10v if the input jacks are not in the chassis.
I'm checking on the 1w resistors before the zeners, those along with all other diodes tested good, I also changed all 4 4558's, and in the pics there are 2 resistors lifted from me trying to narrow down where the problem is.
Where the board is burnt seems to be ok.
![Click image for larger version
